oil loss out vent hose??
Topics related to the ownership, maintenance, equipping, operation, and riding of the R1100R.
Postby coolchange » Fri Feb 05, 2010 9:15 pm
can someone tell me how all the oil could be pumped out through the engine vent hose? hose was not conected to the air box at the time.
coolchange
Re: oil loss out vent hose??
Postby cycleman » Tue Feb 09, 2010 3:14 pm
All that ever should come out of this hose on any engine is vapour. It is part of the polution system. If it is pumping oil you've got a serious pressure issue inside the engine caused by blow by of gases ie: bad rings/engine shot etc.
Was the air filter wet with oil when you checked prior to unhooking this hose?
cycleman
Postby Boxer » Thu Feb 11, 2010 7:34 am
If the crankcase is overfilled.
Woodstock, Georgia
Silver 2010 F658GS Twin
Slablog
Boxer
Postby REALGRAVEROBBER » Wed Mar 10, 2010 2:45 am
It seems that filling the engine with oil above the 1/2-way mark of the oil sight glass will sling oil into the airbox, and suprise a bloke when the airbox drain is removed.
Maybe ... BMW made this vent hose too sensitive to collecting oil. Solution => Only fill to the half-way level. :biggrin:
REALGRAVEROBBER
Return to R1100R
Who is online
Users browsing this forum: No registered users and 1 guest
