2003 r1150r heated grips handgrip installation
dechaoz05
Post by dechaoz05 »
hi all,
new member here. put down deposit a 03 r1150r abs s/ factory heated grips, luggage, windscreen, corbin low seat and then some just yesterday!!
will pick up the r on monday after the current owner taking it in for the final annual checkup this weekend.
have a quick question though. the r now has cracked handgrips. i am wondering where i can get a set of grips for the r (ebay search result shows a new set for $40 free shipping) and how much time it takes to install. i've done something similar on my suzuki katana b4 but not sure if the r is any difference since it's a beemer with heated grips and all. any tips/suggestions?
thx
dean
dechaoz05
Re: 2003 r1150r heated grips handgrip installation
Post by dechaoz05 »
actually, the set which i saw is $32 incl. shipping. says they are for "boxers" after 1976... what does that mean?
sweatmark
Septuple Lifer
Donating Member #: 208
Post by sweatmark »
You get what you pay for. New OE replacements are $130 each. Bargain grips might well be cheap... caviat emptor.
Replacement process is not to bad. You must remember to extract the machine screws that fasten left grip to handlebar, and there's some fiddling with the hand controls module on both sides. This is also one project that absolutely requires tank removal, but that's a good experience for all oilhead owners.
dechaoz05
Post by dechaoz05 »
thx!!
AirForceDirt
Post by AirForceDirt »
Something to consider..
When the grips are cracked or worn, but the heating elements still work, you can change the rubber grip without replacing the entire heated grip assembly. You need two right-hand grips (ask your BMW dealership) which should run you around 20-30 bucks. Then just cut the old grips off and slide the new ones on. You have to be careful, of course, not to damage the elements under the grips, or the wires that run to the end of the heating element, but it's possible, I did it on mine. Its relatively simple, and saves you quite a bit of money.
When I change the grips again from wear, I'll replace the whole unit, but I won't have a choice this next time, but that's a side effect of using gasoline as a lubricant for something rubber.
dechaoz05
Post by dechaoz05 »
thx AFD
so 2 left-handed grips eh? will keep that in mind!!
AirForceDirt
dechaoz05 wrote:thx AFD
Sorry, it's two throttle-side grips...to two right hand grips. My mistake.
dechaoz05
Post by dechaoz05 »
and the 2 right grips are the same as the non-heated ones right?
thx
dean
AirForceDirt
There is only one set of BMW part numbers for the actual rubber grips. Since most BMW's use the same grips, a dealer should have some is stock. I just went to Ironhorse BMW here in Tucson, asked them for two right hand grips, and they went to the back for a bit and came back with both of them. No waiting, no fuss, was out the door in under 5 minutes (any longer and I start looking at the bikes and I don't want to drool on anything).
dechaoz05
Post by dechaoz05 »
i ended up getting a couple of those "over grips" from ebay for $8 a pair incl shipping.... ride 30 miles tonight and they work beautifully
it's a foam overgrip on ebay. i got the size small for my r and it's a perfect fit
Airman
Post by Airman »
dechaoz05 wrote:i ended up getting a couple of those "over grips" from ebay for $8 a pair incl shipping.... ride 30 miles tonight and they work beautifully
Right. "Grip Puppies" I bought mine from California Sport Touring. They work great and don't interfere with the heated grips.
mick Hoff
Donating Member #: 458
Post by mick Hoff »
Here's a link for just the rubber grips ($19.42):
http://www.beemershop.com/catalog/produ ... 59d4686450
here's a link on changing them out:
http://www.advrider.com/forums/showthre ... ight=grips
Hope this helps
Lifetime member # 458
dechaoz05
Post by dechaoz05 »
nice.... thx mick!
