The details.
I have had the experience of breaking down in Lufkin, Tx at 6pm on a Sat with a blown water pump in a Lotus Elan; the local kid at the Shell station said, "Yuk, Yuk, Yuk, I'd say you got big trouble." Yes I did. I have had a broken water pump stopping me dead 3 times in a Volvo (worst car I ever owned)--Peaveley, Mo; Binghamton, NY; and 45 mi from home on US61. And a frozen thermostat in an MGb in Gonzales, La--I could have fixed that, but I was coming home from a Rolling Stones concert (early 70's) and I had "enjoyed" myself. Say no more.
I r e a l l y do not want to break down just outside of Podunk, La with a crippled Roadster, so I decide to switch out the rightly maligned OEM quick disconnects. I did not want to spring $80 for the Omegas, so I read with interest the reports of the Small Parts.com version. I ordered the single shutoff version, but they sent the double. Ok, fine by me.
I tested them--see first post and felt comfortable with the re-connectability. Actually I fell prey to the four most dangerous words in the English language: This Time It's Different.
Here is how the install went--pardon the newbie nature of the pics.
This is where the quick disconnects are--just behind this fairing.
To remove it you must remove the cover for the oil coolers--two screws on the bottom and then lift up.
The top is held in place by 2 pieces of plastic that engage two grommeted holes--just tease it up. You can see the 2 here.
Now you can remove the black cover/fairing--one screw and another plastic engage right in the center.
You are there. They are the two black connectors parallel to each other.
Gas will spill when you disconnect them--have a rag available to soak it up and prevent it from hitting any surface. This is the O-Ring that is mentioned in some threads--it can become dislodged resulting in a leak.
The BMW hose clamps are a bi-otch to remove, but I got them off easily (after fighting with other methods) by using the cutting disk on my dremel and cutting down on the "crown" of the clamp.
To replace the clamps you need to use Fuel Injector clamps; I got these and the hose pincher at Pep Boys. I am very glad I got the hose pinchers--they work well, they travel well, and they fit in a tight space.
The QD's are the same size as the OEMs
After removing the OEM clamp, removing the QD required a little twisting and pulling. Crushing the tubing did facilitate removal, but was not necessary on all 4connections. On removal of the second OEM disconnect, it broke off in my hand with not that much muscle. I feel it was ready to go though not yet symptomatic-but that's the way they are--fine until the strand you somewhere. I was happy to find this before disaster.
I installed the first one without too much trouble, but then disconnected it to go after the second one.
I installed the second one, clicked it together; went to connect the first one and IT WOULD NOT CONNECT. I eventually removed one limb of it and forced it together. Then I reconnected it.
While doing this I realized that what I had was a very fancy and expensive straight tubing, like many on this and other boards recommend instead of the QDs.
The completed project (leak free, btw.
So , would I do this again. Yes, I would definitely replace, but I'd use straight tubing. In fact, I will carry a couple of 3" lengths and a hose pincher just in case.
The vital stats on the bike--2004 with just under 18,000 miles. 12,000 mile service at dealer. 18k will be by me.
Oh, one last thing. The fuel injector clamps worked fine, but the screws are a little long and I had to be careful positioning them that their bare edges would not rub on , and possible through, something back in there
