I feel justified carrying the two straight brass connectors in my tool kit.
Is the hose pinch to prevent the flow of fuel? I thought it would not flow unless the pump was running, am I mistaken there?
DJ Downunder wrote:Has anyone using straight copper tubing had an issue with leaks or is anyone worried about it coming apart? The connectors all have "barbed" ends to help hold them in the fuel line.
Good question....I'm looking for some straight pieces of tube to replace the dis-connects..but I'm looking for some tubes with those barbs on each end.
I'm sure they're out there..I have not really started looking yet..I'll let you know if I find any....There's a lot of pressure in those lines.
Some others here have just used straight tubes without any problems...but the barbed ones would give me better peace of mind.
boxermania wrote:Most vehicles fuel systems are equipped with Viton 0-rings, Buna N is a second choice on use.......Viton and Oxygenated Fuels are not a good choice.....but I'll talk more about that in another post.
Users browsing this forum: No registered users and 1 guest
